Old 02-20-2022, 05:13 PM
EternalArianne EternalArianne is offline
Default Squealing around PTO while on low throttle
So I drove my 2155 over to my neighbors earlier today and just parked it while we talked. I turned the throttle down low and just left it idling. It sounded fine, he even commented on how good it sounds after the recent tune up.
Then we started hearing a faint squealing noise. I opened the hood and it seems to be coming from where the front shaft connects to the PTO. I turned the throttle up and the noise went away.
Later after I drove back home, parked, and lowered the throttle to a low idle, I heard it again. Raised the throttle and it went away. It's not an ear-bleeding squeal, more of a low noise that goes away once the throttle is ramped up.
Is the PTO clutch going bad? Or could it need some kind of lubrication?
Old 02-20-2022, 06:14 PM
I'd be looking at the drive belt idler pulley.
Old 02-20-2022, 06:58 PM
Since this tractor doesn't have a drive belt, do you mean the PTO mule drive pulleys? But I didn't have the PTO engaged when hearing the noise, so those wouldn't have been a factor..
Old 02-20-2022, 07:55 PM
My Bad,
I looked up what I thought was a 2155 and it showed it was a belt drive.
Apologies are in order.
Since the noise seems to be coming from the pto area,
on the older tractors I'm familiar with, the PTO would be a good place to look.
sometimes a little grease injected under the bearing seal lip with a diabetic syringe, will allow the bearing to last a long time.
Old 02-20-2022, 08:15 PM
No apologies needed George, we can't be human if we don't slip a bit now and again lol. I'll try to shoot some grease down in the PTO clutch and see if that helps. I've greased every fitting I could find that had a zerk, but didn't see one on the PTO.
Old 02-20-2022, 10:34 PM
Farmall450's Avatar
There's not one, but these work.
https://www.farmandfleet.com/product...or-needle.html
