Old 02-19-2022, 04:59 PM
Blackstallion Blackstallion is offline
Default LTX1042 and 48" Plug Lawn Aerator?
Can't find a towing spec, but would my tractor have enough power to pull this plug aerator?
https://www.lowes.com/pd/Agri-Fab-48...erator/3029620
Old 02-19-2022, 05:33 PM
First, welcome to OCC.......
I would say, depending on the weight that was added, unless it was extra heavy, your lawn tractor should handle that implement.
Old 02-19-2022, 09:41 PM
Farmall450's Avatar
Without a problem. Get some good gloves for when you plan to put it together, they've sharp! And if the ground isn't soft...good luck
