Old 02-09-2022, 02:12 PM
EternalArianne EternalArianne is offline
Default How often do you change tires?
As far as I can tell, the rear tires on my 2155 are the original Cub Cadet branded tires from 20+ years ago. Tread is still good but only one holds air the other I had to put a tube in.
Do you guys just keep using tractor tires until they fall apart or blow out, or do you replace them when they get old even if the tread is good?
Old 02-09-2022, 02:29 PM
For me, as needed.
Old 02-09-2022, 04:03 PM
Red Dave Red Dave is offline
In 2019 I replaced the rear tires on my 125 because the sidewalls were badly cracked and falling apart. I believe they were originals, so about 51 years old. That tractor also sat outside for some years before I got it, so probably had some UV light rot. Tread was still good, sidewalls were shot. It is a working tractor, not a show piece.
If they had not been in bad condition, I probably would not have bothered.
Old 02-09-2022, 05:32 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Replace when nothing else will keep the air in , as Roland says when needed
Oz
Old 02-09-2022, 06:39 PM
Farmall450's Avatar
Oz
Ditto. Generally by the time they start leaking they're so hard you can just throw a tube in and have a bulletproof tire.
Old 02-10-2022, 07:51 AM
IHCubCadet147's Avatar
All of my tractors have the original rear turf tires, 40+ years old, a few have had the fronts replaced before I got them. I don’t replace them unless there is something wrong that can’t be fixed with a tube, which hasn’t happened yet. Maybe I’m just too picky, but I don’t think the old ones look right with newer turf tires. If I was going to buy new tires for any of mine, they would be ags and tri ribs, but I’m too cheap for that.
Old 02-10-2022, 01:31 PM
I mirror what others said, if a tube and/or a boot will not fix it,then it needs replaced,otherwise keep on rolin'
Old 02-11-2022, 04:53 PM
Ozcub's Avatar
Or you could solid fill them and they will last forever
Oz
Old 02-11-2022, 05:02 PM
evhevh evhevh is offline
I agree with all the others. Run them as long as possible. Put a tube in it when they will no longer hold air. My front left has 3 plugs in it, no tube, and it holds air just fine. Surprises me given how thin the front tires are.
