Old 01-27-2022, 01:41 AM
1811woody's Avatar
Default Hydraulic Pump differences?
Can someone please direct me to the info or explain the differences between the two pumps. Other then ported or non-ported. From my understanding there is a Sunstrand and a? I know so little about them. I'm not even sure my question is right.
Old 01-27-2022, 07:01 AM
Sunstrand Pumps
The SGT's used pumps with a different output shaft to mate to the 68 tooth reduction gear. The GT's had a different output shaft to mate to the 66 tooth reduction gear.
Then Cub Cadet used the Hydro-Gear hydro pump on models like the 1440, some 1541's, 1641, 1861 & the 1863's. I believe those machines were priced a little cheaper than models with the Sunstarnd pumps when new.
Old 01-27-2022, 08:30 AM
Cub Cadet used the Sundstrand 15U Hydro's, in their Garden Tractor line up. There were two versions. (a) Ported, and (b) non-ported. The Non-Ported was the most popular, used in the majority of tractors. The "ported" hydros were used in tractors that had "front hydraulic outlets".
Cub Cadet also used Hydro Gear and Peerless transmissions for the entry level equipment for a lower prices. Mainly seen in Lawn Tractors.
Old 01-27-2022, 08:46 AM
Sunstrand Pumps
One can change the Sundstrand output shaft gear, but it requires disassembly of the hydro.
There is one tooth difference between them, with the super having one tooth less than the non super models, as it makes up for the larger rear tires on the super making for the same in overall speed of the tractors.
Old 01-27-2022, 12:56 PM
1811woody's Avatar
Are there different manufactures of pumps and the only dif is the name?
Old 01-27-2022, 08:21 PM
Sundstrand and Hydro-Gear are 2 different company's and their pumps are completely different.
They completely switched to Hydro-Gear on the 3k series and up. That series started in 1998.
Old 01-28-2022, 01:30 PM
1811woody's Avatar
Once again thank all you for the info!
Old 01-29-2022, 05:16 PM
Dart1917 Dart1917 is offline
Ported hydros were used with a single spool valve on tractors with hydraulic lifts. A 2 spool valve was used with the ported hydros for the front hydraulic outlets.
Old 01-30-2022, 09:16 AM
I respectfully disagree.
Old 01-30-2022, 10:15 AM
Frank1541 Frank1541 is offline
See the link to a picture of the ported and non ported pumps. A ported pump can handle one or more external hydraulic circuit. It does not define how many circuits are used.
https://onlycubcadets.net/forum/showthread.php?t=4675
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
