Thread Tools
Display Modes
I got the other twin running. Mice chewed through one stator wires. Started right up. Not know the real history of the machine, I followed the static timing tech article in the tech library. I used the rebuild article for turns out on the carb. I also used the wiring diagram to trace wires and used the stator and coil resistance articles also. Thanks much to those that contribute!
Now not to compare children, but the new older external brake model I just got running has definite gear noise coming from the rear. The drive flange on the trans is sloppy the shaft sticking out of the trans is tight. The drive shaft wobbles ⅛" maybe a lil more. New flex disc joint. I will check lube levels tomorrow.
![]() ![]() ![]() '76 1200 Dad bought '75 1200 "Twinsie" per my daughter |
What model of Cub Cadet are you working on??
Sorry, my 1200's.
There is substantial slop in the ball bearing spacer flange. Hopefully Jeff makes them! The rear end noise, reminds me of my friends Kubota's. I did elect to try Jeff's solid mounts and a solid ebay, 3 finger drive. Both quality pieces of work!
