When I engage the PTO on my 2155 it starts out sounding fine (engine ramps up and I hear the belt moving on the pulleys) but after like 10 seconds it sounds really loud/terrible and the deck itself vibrates a bit once the blades get to full speed.
I removed the deck entirely and inspected both the PTO and deck belts, they seem in good order. Found the left blade had serious wobble so I replaced the spindle bearings. The right blade has no discernible wobble that I can notice. Both blades look the same, not bent or missing metal. Both blades spin freely not hitting anything. I put the deck back on the tractor and still the same thing, super loud and vibration after 10 seconds of engaging the PTO. I have no experience with front PTO (horizontal shaft engines) tractors, is this normal operation for it to make a lot of noise when engaged? It seems quite loud compared to ones I’m used to with bottom PTO (vertical shaft engines). The only other thing I can think of is replacing the right blade spindle bearings (even though there isn’t any wobble) and replace the actual blades themselves. |
Most likely a bearing.
Just because they're not loose doesn't mean they're not bad.
JD x475 |
Take the belt (PTO to deck) off, and turn on the PTO. Is the noise there ??
That was one thing I did check while the deck was off. No sound at all if I engage the PTO with nothing connected.
![]() Quote:
Thanks, that’s why I was thinking. I shoulda just replaced the bearings on both sides and been done with it.
Grease is a replaceable thing to, you know
JD x475 |
I did a few pumps of grease in both spindles before putting the deck back on.
I actually used it to cut grass today (previously I was just testing it short term). I guess it’s about as noisy as any other mower, or I just tuned it out and was happy to be cutting with my own mower instead of borrowing the neighbors lol |
The bearings in the double deck drive pulley may be bad also.
Check the bearings in the idler pulleys also any dodgy bearing will make a heck of a noise
Additionally the 2 pulleys where the belt does a right hand turn from the PTO to the deck check them , any grinding noise or feel as you turn them the cure is replace Did you get the deck height fixed? Oz
My wife says I do not listen , at least I think thats what she said |
