I have an old Model 1529 which is a 46" cut, 3 blade system. I have replaced belts, spindles during the past couple of years. Two days ago, the deck belt flew apart into pieces & I went to the shop that I always get parts for. The old belt pieces did not have a number on it, so the guy looked it up on his computer. He had a hard time finding the belt this time, but finally gave me a belt that measures 5/8" x 101". Like I said, I have changed this belt a couple of times, but I cannot make this belt fit, because it is way too long . I went back to the shop & he insist that it is the right belt. Unless I am losing my mind, I cannot make it fit.
Does anyone have the correct measurement of this belt. It IS the deck belt, not the one that goes around the PTO. Thanks in advance ! |
Cub Cadet 754-0640
(Superseded to 954-0640) Belt, .50" X 79.24" https://www.partstree.com/models/152...-mower-deck-0/
![]() 582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
Using the Cub Cadet Parts & Service Lookup tab at the top of the page, the deck belt that engages the spindles is: 954-04011 V-BELT B SEC x 101.2
A 5/8 " x 101" , a tad shorter is what he gave me. I am going to post a picture. Unless my memory has gone bad, you can completely install this on the removed deck.
Deck & the belt
I would suggest you click on the tab at the top of the page and type in "1529" and pick out the belt you are looking for.
Ref:
40 954-04011 V-BELT B SEC x 101.2 This part replaces 754-04011. Isn't this the belt that wraps around the 3 pulleys/spindles for the blades ? It wraps on the bottom of the double pulleys. The other belt seems to wrap around the PTO & the top pulley of the two outside spindles. |
In the pix of the deck, it is wrapped around the idler & the center pulley.
![]() Quote:
The one I looked up was the Deck/Spindle belt.
Per page #27 of the Owner's Manual....
