Old 05-22-2021, 10:21 PM
kentross81 kentross81 is offline
Default Traction: ZT1 vs ZT2?
I have a 42" ZT1 which I really like, however our 2-3 acre mowable area has a serious slope to it.
I have to be very careful not to rip up the grass when turning or stopping, and even when dry it is easy to slide (1 wheel not turning, a skid).
While mowing across the hill (recommended safest way) the back end will slip down the slope a few inches at times in a couple areas.
Obviously our lot isn't right for a ZT, a conventional tractor would be better- sorry, I am a ZT guy!
Does the ZT2 have better traction, or worse? I bought the ZT1 thru Home Depot, and have the ability to return it for full credit, to hopefully get a ZT2 from them. Just a matter of.... is it worth it.... a lot more cost.
If the traction is better, and I won't rip up my lawn as easily, I need to think about it.
Thanks for any help.
Old 05-23-2021, 05:49 AM
bugeye bugeye is offline
While I have no experience with a ZT, I do experience some traction issues with my garden tractors. I have found the tire tread will have an effect on sliding sideways when mowing across the slope. Suggest comparing tire size, tread width and tread aggressiveness. I run wheel weights for mowing and snow removal.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 05-25-2021, 07:23 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
I doubt it would make any difference. Zero turns suck on hills.
They all do.
JD x475
Old 06-06-2021, 12:56 AM
GregBert70 GregBert70 is offline
Default 12" tires vs. 8" tires
The 12" tires of the ZT2 would obviously be better than the 8" tires on the ZT1. This brings up a question I myself have had. I had my heart set on a ZT2-50, due mainly to the serviceable hydros...but they just cannot be found- not here in Ohio anyway. I have thought about putting the 12" tires and wheels from the ZT2 on my ZT1, but then I thought- would the increased traction from the 12" tires put more strain on the non-serviceable hydros? Or, is it simply an upgrade that would have no bearing on installing them on a ZT1. The serviceable hydros, the 12" tires, and the arm rests were why I really wanted the ZT2. I don't care much about the larger front tires, or the wider strip of steel welded to the leading edge of the deck.
