Old 08-17-2010, 01:40 PM
cubcadet109 cubcadet109 is offline
Default 109 Hydro issue
I recently got a free 109. All the sudden, the hydro just speeds up without warning(this started happening like an hour ago). The lever seems a little losser. How do I make the hydro so it doesn't speed up? Thanks.
Old 08-17-2010, 03:36 PM
rmunro's Avatar
rmunro rmunro is offline
http://www.onlycubcadets.net/forum/s...t=hydro+adjust
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 08-17-2010, 03:46 PM
Aroostook Aroostook is offline
Exclamation 1x9 Trans Controls
Start by seeing if you can tighten #16.
Old 08-17-2010, 05:06 PM
If that doesn't work for you then you may want to repair your trunnion, go here.
http://www.onlycubcadets.net/forum/s...union#post9162
Then go here.
http://www.onlycubcadets.net/forum/showthread.php?t=43
And here.
http://cubfaq.com/hydrolurch.html
And finally here.
http://cubfaq.com/trunionrepair.html
Then after you get that fixed you will need to go here.
http://cubfaq.com/neutraladjust.html
I think that should pretty-much take care of it.
Old 08-17-2010, 06:11 PM
Default Shims
Where do you get shims that size? Make them?
Old 08-17-2010, 06:24 PM
Not unless you have a punch press. McMaster-Carr has them; that's where I got mine.
Old 08-17-2010, 08:29 PM
Default Ok
Okay, I've got it figured out. Thanks for the help guys.
