Old 04-16-2021, 12:12 PM
pwoodman1969 pwoodman1969 is offline
Default 682 Lift Handle Help won't raise deck
Just put a 44c mower deck on and the lift arms seem to be oriented incorrectly with the lift handle because in the up position it will not even raise the deck off the ground. The 682 was given to me along with an 1810 and the lift handle on it appears to be be oriented correctly to raise the deck. Before I go pounding on roll pins can the orientation be changed by removing the roll pin from the lift handle and repositioning it on the shaft?
Thanks all...
Old 04-16-2021, 01:26 PM
Well there was no roll-pin so it rotated on the shaft, nice bolt in there now.
