Old 04-12-2021, 10:19 AM
Ambush Ambush is offline
Default Identify This Cub?
This Cub is coming up on the on-line Ritchie Bros Auctions but has precious little details. Looks like it has a hydraulic lift, all the mule drive and rear angle drive for a tiller. No decals that I can see. VIN # is 20506600569191
I know a bunch of you guys will know what it is just by one pic.
And if it turns out to be a parts tractor, how is the parts compatibility with a 149?
Thanks!
Old 04-12-2021, 10:34 AM
Should read: 2050660U569191
It is the Quietline Series and appears to be a 1450. Made in Nov of 1975.
Old 04-12-2021, 10:42 AM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
Something's off with that serial number, there's supposed to be a "U" between the identification numbers and the actual serial numbers to indicate being built in the US.
Nonetheless I will break the number down:
-The "205" at the beginning of the number indicates that it is a Garden Tractor.
-Then, the "0660" in the beginning of the number indicates a 1450
-After that there should be that letter "U" (which is probably mistaken for an extra "0" in the number you provided)
-And the rest is the serial number of the tractor, which indicates a November 1975 build date.
Hope that helps
Edit: Roland got me
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 04-12-2021, 11:28 AM
Great, thanks!! I'll have to decide if it's worth the drive.
Old 04-12-2021, 11:47 AM
I have a 1450 also. One of my favorite tractors.
Old 04-12-2021, 01:31 PM
Tail light lenses will be hard to find.
Decal set about $65??
Not much in the drive line will interchange w/a 149 though as the 149 had ISO mounts and a cradle mount for the engine and an electric PTO.
Does it run?
If so, $300 tops in my world IF I wanted/needed it.
Be nicer if there was dual hydraulics.
Old 04-12-2021, 05:30 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Looks like a nice next project to me!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
