Old 04-11-2021, 12:11 PM
sonofsquink sonofsquink is offline
Default Pulley replacement on 44" deck
Hey guys,
I have a 441U1111 mower deck for my 149 that has two busted up pulleys that need to be replaced before mowing season hits.
The parts lookup calls for IH-59703-C2 for the center double and 756-3008 for the single.
Before I drop around around $100 is there anything I should consider? I've read several threads about a "speed-up pulley" for the center with views on their merits varying widely, so does anyone have thoughts on that?
Also, it took a big filter wrench and a lot of PB blaster and cursing to get the double pulley free from the spindle with that pulley-mounted nut being so far in that well, is there any literature or tips on how to make that process any easier?
https://www.messicks.com/part/ih-59703-c2/pulley-double
https://www.messicks.com/part/756-3008/pulley-v-4-6
Old 04-11-2021, 01:01 PM
What model of Tractor is this deck mounted to??
Old 04-11-2021, 01:17 PM
The 149, I have the whole deck apart to prep for a good sandblast/paint right now. Planning on using rustoleum almond unless anyone has any better advice, the paint threads are a wealth of information on here
Old 04-11-2021, 05:11 PM
The 441U1111 is the first generation 44" deck. The double pulley for that deck is: IH-50973-C2.
You can increase your mower deck tip speed by using the IH-126393-C1 that was used on the 441U1113 decks.
The outer pulleys remained unchanged.
Old 04-12-2021, 10:18 AM
Thanks for the info sir, would there be an aftermarket center pulley? Seems like that is out of stock on most the sites, the only one I found was used and the guy want $140 for it. Maybe I'll give the cub dealer a buzz
Old 04-12-2021, 10:31 AM
Not aware of an "aftermarket" pulley. Since the part is NLA, the hucksters know this, and ask ridiculous prices.
Old 04-12-2021, 10:42 AM
twoton twoton is offline
I wouldn’t bother trying to chase down a ‘speed up’ pulley. I have both and the stock 5” does just fine.
Old 04-12-2021, 11:09 AM
As always, thanks for the advice gentlemen, I really love this site
