Old 04-06-2021, 09:44 PM
modcub72's Avatar
modcub72 modcub72 is offline
Default Rejuvenating motor-driven PTO
Is it possible to clean out old grease, clean and regrease front motor driven pto?
Old 04-06-2021, 09:47 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
Not sure what kind of PTO you're referring to, but if it's a mechanical one I don't think it's supposed to have grease in it at all! Heck, I don't think electric ones should either!
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 04-06-2021, 09:55 PM
modcub72's Avatar
My bad, for the old narrow frames.
Old 04-06-2021, 09:57 PM
modcub72's Avatar
Motor driven PTO bearing for 72, 104 and 124.
Old 04-06-2021, 10:15 PM
modcub72's Avatar
.......lol, crickets?
Old 04-07-2021, 06:38 AM
finsruskw finsruskw is online now
Clean and dry.
It's a friction device.
If it is greasy you must have an engine oil leak nearby or the bearing is about to give up the ghost.
There is NO lubrication for a PTO, regardless if it is NF or WF, Mechanical or Electric.
Old 04-07-2021, 07:18 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Personally, I'd just replace the bearing....I've been known to regrease bearings but not this one.
Plow blade
#2 Cart
QA36 snowthower
Old 04-07-2021, 08:09 AM
Not familiar with your PTO. But a ball bearing can be re-lubed by using a Diabetic syringe filled with grease, injected under the seal lip.
Been doing it on old farm machinery for over 60 years. And the PTO bearings on my cubs. Yep I'm thrifty and it works.
Old 04-07-2021, 05:08 PM
modcub72's Avatar
Thanks ol' George.
