Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 04-05-2021, 08:12 PM
Vertigo1 Vertigo1 is offline
Default Starter removal WG600 engine, in a 2182 ?
I took the 2 bolts out and it hits a steel plate that won't let it out. The plate had 2 engine mount bumpers, which I removed. The plate seems like a major pain to remove, but don't see any other way.
Any suggestion's would be greatly appreciated.
Old 04-05-2021, 11:44 PM
Bryan S Bryan S is offline
I have replaced the starter in my 2182, that was many years ago. I never looked into the how to on the net, the net wasn't all that old,
so I never thought to do it way back when. I do remember sitting there what seemed like for days thinking, cussing out loud, and the neighbors probably thinking I have anger management issues, which all mentioned is true.
That being said, I think and thought at the time, that you had to at least undo the engine, and lift it up and out a bit to get that starter out. I said out loud, F THAT! and grabbed a Sawsall and cut the corner of the block/ piece of something off? Can't remember what piece of what but. Now I can change the starter in about 5 min or less. Was it right, no, but it never presented a problem for the past 15 years or so, so...
You know, I never did look it up, prob will now just to see what others have done/do.
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more"
Old 04-09-2021, 10:06 AM
Thanks Brian S.
I'm going to try to cut that plate to remove it.
Old 04-21-2021, 11:38 AM
Update! Did not cut the plate. Instead, hoisted engine up about 4-5 inches on the starter side, took out 3 of the 4 bolts holding the plate to the engine, loosened the 4th bolt (the one you can't easily get to, lower left I think) and the starter almost fell out.
Pretty bad design, in my opinion, but defiantly solid metal to work with.
FYI
