Old 03-31-2021, 09:22 PM
thejum57 thejum57 is offline
Default Grass catcher
Is there anywhere to buy a grass collection system for a 2007 LT1050 mower?
Everywhere I look, they always specify 2015+ I'm sure they were available for older mowers. Is there that much of a difference between 2007 and 2015+ models?
Thank you,
Jim
(new member)
Old 04-01-2021, 01:30 AM
Bryan S Bryan S is offline
Thank you,
Jim
(new member)
The 2015 and above reference is for the new X1 series 1050's or whatever the Hell they are called now.
The LT, LTX, LGTX, SLT, SLTX etc. 1050 like you have, stopped production in 2014. There's a lot of used baggers on Craigslist, that can be had cheap, sometimes Ebay too.
I've seen new ones (bought and never used) for about $150.-$200 on there as well. The part number you'll be looking for is 190 (190-190-100) - Cub Cadet Triple Bagger attachment,
also MTD brand will work as well. Also I think for your area, people ask way more money than here in cow town. HTH
Link for you. https://www.partstree.com/models/190...al-assembly-0/
EDIT: Here's one on CL in Boston area. https://boston.craigslist.org/gbs/gr...298216652.html
EDIT2: If you have your heart set on a new one, well here you go. https://www.walmart.com/ip/MTD-Tripl...2100/342115399
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more"
Old 04-02-2021, 09:36 PM
Thanks for the info. I'll look around for something used but if I can't find anything the MTD should fit? The deck mount and chute to the back? I know it's alot $$$, but at some point I may be forced to. I mow some lawns on the side and most like the clippigs piicked up. Thanks again !!!
Old 04-03-2021, 11:30 PM
Well evidently there is more than one model that will work for your tractor. This Model number (19A40002100) will work as well.
If you copy and paste it at partstree it has 2 applications. 2013 and before and 2014 and after. It's listed for the 50" and 54" deck model Cubs.
HTH you in your search. Triple bagger Model # 19A40002100
EDIT: Link to partstree for you. https://www.partstree.com/models/19a...e-rear-bagger/
