Old 08-15-2010, 10:03 PM
Darrell Darrell is offline
Default NF driveline replacement help
Hey Guys , The throwout bearing flew apart on my 126 loader tractor , so need to replace some parts. Probably going to replace everything while it it apart.
I have never replaced the drive setup on a narrow frame before , is it as big of a PITA to do as it looks ??? Looks like you have to pull the motor or slide it forward ?? It also has a creeper in it.
Any tips/tricks would be helpfull since this may be a one man show !!!
Thanks ,
Darrell
Old 08-15-2010, 10:10 PM
Yep, you have to slide the engine forward. It might be easiest to remove the grille casting and engine. If you have a creeper, it's actually easier to get at the rear spirol pin because you can access it through the lift handle slot. It's probably going to be a pain because of the loader. This is why my loader is no longer on a NF gear drive and will be on an 82 series hydro
Replace pretty much everything while you are in there. Pilot bushing, driveshaft, friction disc, teaser spring, main spring, throwout bearing, spirol pins and true up the pressure plates on a lathe.
Old 08-15-2010, 10:15 PM
Thanks Matt , that is what i thought. I do plan to replace everything while it is apart.
I have followed your loader thread , and i am wishing my loader was on a WF now !!
Old 08-15-2010, 10:26 PM
Nice 126 and loader, Darrell!
Old 08-15-2010, 10:38 PM
Sminkey
Guest
Posts: n/a
Default I agree with Allen
Nice tractor
Old 08-15-2010, 10:46 PM
Nice 126 and FEL!
Old 08-15-2010, 10:51 PM
johncub7172's Avatar
Nice loader! Nice tractor, and is worth the new drivetrain parts. Gear trans. are pretty tuff, though.
