Old 02-18-2021, 10:35 PM
DRohacek DRohacek is offline
Default Flat head converted to overhead valve
This pulling engine is an aftermarket flathead Jones block . It is a heavier built block modeled after a Kohler K series that uses K series type parts. We turned this into an overhead valve engine using an Oldsmobile 455 head with roller rockers and other aftermarket parts inside to end up at 53 cubic inches and 13.5 compression
Old 02-18-2021, 10:38 PM
More photos
Old 02-18-2021, 10:52 PM
Couple more
Old 02-20-2021, 06:54 PM
twoton twoton is offline
Very cool.
Old 02-20-2021, 11:29 PM
Originally Posted by twoton View Post
Very cool.
Thanks. I started with the Stromberg 2 barrel on gas but eventually changed it to a 44 Mikuni side draft on Methanol.
Old 02-27-2021, 11:20 AM
V30crewcab V30crewcab is offline
that is impressive. why cut up the head though, would it not be easier to build a custom head, or is that not allowed in the rules?
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 02-27-2021, 09:07 PM
To make a head from scratch out of billet aluminum would require a tremendous amount of machining. When you are done it would not necessarily be any better. No need to reinvent the wheel, just adapt a known good wheel to the project. Additionally, I acquired this head from a friend because it had a crack on one of the intake ports where it had been ported to deeply. Essentially it was junk to use on a V8 again but was perfect for my plan and big valves had already been installed. I used roller rockers and fit it to the block.
Old 02-27-2021, 09:20 PM
Intake is 2.15 pretty good flowing head to.
File Type: jpg C9D698F0-3A96-46AD-831B-1E99E4FC58FE.jpg (25.0 KB, 193 views)
Old 02-28-2021, 10:06 AM
cool. its amazing what you can make work!
72 scout
IH 404 tractor
Old 04-14-2022, 01:18 AM
Odmark Odmark is offline
This is so cool! I would love to hear it run
1974 Cub Cadet 128
1968 Cub Cadet 105 Hydrostatic
1963 International Travelall
1976 International Scout II Traveler 392
1977 International Scout II Traveler
http://www.garaget.org/Odmark - A page for my cars (swedish, sorry)
