Old 02-09-2021, 08:16 AM
OldBlue OldBlue is offline
Default Weight Ballast Build
I've got a 782 with a 3 point hitch and snow blower. I want to make a weight for the 3 point out of 5 gallon buckets and a draw bar. I know the top mount is 12 inches above the bottom mounts but how do I decide the height of the draw bar? This is my first tractor with a 3 point so I'm still figuring this out. If the bucket is sitting on the ground and I put the bar through at the lowest arm setting to hook up, won't the bucket drag when I lower the Snow plow? If I lower the attachment points I'd have to set the weight on a base to keep it high enough to hook up. Is that correct?
Old 02-09-2021, 03:17 PM
Forget the bucket and drawbar and do this.
Build a box, support it with the lower 3 point and hang it from the frame.
I built three of these, one for each of the cubs that need winter traction and they work like a charm.
Paint it to match, add a piece of reflector tape and a short length of tow chain and it will look like it belongs there.
Speaking of chain, it's also a good place to carry a chain for if you plow long enough you will more than likely need one sooner or later!!
Old 02-09-2021, 05:50 PM
Looks good!
That gives me another project to think about.
