Old 01-26-2021, 08:30 PM
DSarow DSarow is offline
Default 125 Linkage Problem
My problem lies in the carb linkage and or govenor settings. At 3/4 throttle it will lope and throttle down. If you watch the linkage that connects on the top of the carb, its jumping back and forth. If you hold that linkage you can steady the lope and it runs steady. Let go and back running crazy. Where should I start?
Thanks.
Old 01-26-2021, 09:04 PM
Do you have all the springs in the correct holes?
Governor and carb adjusted properly?
Check the service manual.
Old 01-26-2021, 10:26 PM
Is this an issue that just started. Worked on it before? Throw out a little more information and folks can probably work you thought it.
Ken
Old 01-26-2021, 10:42 PM
Default 125 linkage problem
I had sent the carb off to be rebuilt. I believe I reinstalled and adjusted it although, it also back fires now a bit if you quickly throttle back. I'll recheck everything.
Old 01-27-2021, 06:48 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Seems like the governor is chasing and, with the backfires, the engine is running lean. Does it help when you richen the carb? Or, for diagnostic purpose, you could pull the choke out a little and see if it helps.
Plow blade
#2 Cart
QA36 snowthower
Old 01-27-2021, 09:20 AM
OK, I'll try that. 7 degrees, might not start.
