Old 01-18-2021, 12:12 PM
thadscub's Avatar
thadscub thadscub is offline
Default The latest Hytran
Hi guys,
I am in need of more hytran for my Cub Cadets. All I can find at the case construction dealer, is hytran premium. Is that okay to run in my Cub Cadet 122 and 123 ??
Thad
Old 01-18-2021, 12:43 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
RUN IT, ain't gonna hurt nothin'.
In fact it's name brand hytran so it's probably the "best" choice to use, but there's many, many other fluids that'll work just fine.
After all, it's an old garden tractor, not a million-dollar sports car
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 01-18-2021, 01:33 PM
Here is the current Hy-Tran product.
Old 01-18-2021, 02:51 PM
thadscub's Avatar
can't seem to find hytran ultratraction at the case dealer all i find for sale is hy tran premium thad
Old 01-18-2021, 04:56 PM
ironman's Avatar
ironman ironman is offline
You don't need hytran in the 122. (unless you plan to run it at Indy)
Old 01-18-2021, 08:19 PM
mortten mortten is offline
Get Mastertran Ultraction at a New Holland dealer. Same stuff. About $25 a gallon.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 01-19-2021, 04:00 AM
Bryan S Bryan S is offline
I agree. Not sure how close you are to this TSC, but myself, and many others here, use this. If you are only doing one tractor they have it in a 2 gallon jug for about $23.00 I get the 5 gal pail for $40.00 because of doing multiple tractors. https://www.tractorsupply.com/tsc/pr...cm_vc=-10005##
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more"
Old 01-19-2021, 12:20 PM
bill682 bill682 is offline
Hy-Tran Premium is the latest name. I have read that it is made by Shell but have not seen any documentation to support that claim.
https://www.mycnhistore.com/us/en/ca...lic/p/73344265
Old 01-19-2021, 12:42 PM
WOW that picture is big!
The 122 don't need hy-tran, most gear oil types will work fine. All it has to do is stick to the gears and bearings.
The 123 doesn't need specifically hy-tran either but it shouldn't be run on gear oil. You need a proper trans-hydraulic fluid, some say ATF works fine (it probably does) I personally use this brand called "Harvest King" available from a local store called Runnings.
They sell this specific type that is made to meet requirements of Case-IH hy-tran, that's what my 107 runs.
At the end of the day, like I said before, this is an old garden tractor, not a million-dollar sports car
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 01-21-2021, 07:26 AM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
They recently switched from having Hy Tran produced by the Viscosity Oil Co. to having it produced by Shell. The new formulation is called “premium” and is formulated to be used in any IH made equipment new and old.
I lost track of what I own a long time ago!
