Old 08-13-2010, 03:15 PM
Tash329 Tash329 is offline
Default K161 Engine Crank Question
Going to rebuild my K161 Kohler for my orginal cub. I was wondering if there was a K181 crank that is made or was to fit the K161 which I believe has the shorter PTO crank end, or will any K181 work.
Old 08-13-2010, 05:48 PM
Gotta see if I remember all of this correctly...
The 161 & 181 both had the same bore, the stroke is where the difference is. So any 181 crank that you find will be a longer stroke than a 161 crank.
The size of the PTO end will probably vary depending on what application the crank was made for. For instance; a crank that was made for a water pump may be threaded on the end, a crank for a green tractor may be a different length and/or diameter, I don't know that all 161 or all 181 cranks were the same on the PTO end.
Someone please correct me if I have my facts confused.
