Old 10-14-2020, 09:04 PM
felwin felwin is offline
Default Hsd 2135
Hi Folks
Im new here. Im in Australia and have issue with my hydro static drive "Cubbie".
It was going great until I replaced the oil and filter and now transmission wont engage. Axles rotate opposite, good. Drive shaft running. I suspect problem is drive disengage lever. I used 15W40 oil and a Ryco filter (with valve). I've redrained oil and poured back in while turning axle (advised this may resolve any air locks) but still no joy.
If anyone has thoughts Id love to hear them. Regards Frank
Old 10-15-2020, 12:13 AM
RLause's Avatar
RLause RLause is offline
Welcome to OCC. Awhile back I purchased a 1863 that would not move forward or reverse. Turned out someone put a B/S engine oil filter on the transmission. Filter would not allow any oil to suck up to the pump. Changed the filter and it worked perfectly.
Richard
Old 10-15-2020, 06:52 AM
Welcome to OCC..........
The 2135 needs to following Parts:
* 923-3014 Hydro Filter
* 737-3055---> 737-3120--->490-000-C051 Hydro Oil
Old 10-15-2020, 09:14 AM
Wrong filter use one of these.
Cub Cadet 923-3014
NAPA 1410
Wix 51410
Fleetgard HF6096
Baldwin BT8486
Old 10-15-2020, 04:08 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
I agree with the above statements, make sure you use the correct filter. The genuine Cub Cadet one is possibly best, but the others listed above will also work just fine.
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 10-21-2020, 01:43 AM
Ozcub's Avatar
Ozcub Ozcub is offline
Wrong filter , go genuine with the Hydro , on the engine you can use a Toyota Corolla filter
Oz
