Old 07-07-2020, 04:08 PM
pcampbell pcampbell is offline
Default CH18S down on power , knocking ? Next steps
My CH18s in my 2518 had a sudden loss of power combined with some pretty nasty clanky knocking sounds. I suspect rod knock but not sure yet. Need some help for next steps. I will do a compression test on both cylinders. I am not sure if I know how to do a leakdown test on this motor, yet. What else? What should I be thinking for rebuild, or replacement?
Can I buy a new drop in motor . I see a couple on Northern Tool that look pretty familiar.
Example:
https://www.northerntool.com/shop/to...2772_200632772
What else should I be considering?
2004 CC 2518 48" deck
Johnny Jr plow/bucket
Carlisle All Trail's 23x10.5 & Firestone 3 rib front
70# weights per wheel
160# suitcase weights in rear
Old 07-07-2020, 04:30 PM
Since there are hundreds of variations of the CH18S, the one that would be the "drop in" replacement would be.... CH18S-62588 Kohler Engine
Old 07-07-2020, 04:39 PM
Both cylinders giving me 150psi.
Here is a video , sound is not great
https://www.youtube.com/watch?v=ZK4y70AH7xw
Some more info on my exact model, not sure if these are exactly correct.
https://sleequipment.com/kohler-18-h...h18-62588.html
Old 07-07-2020, 05:06 PM
Check your rocker arm action. Sounds like one may not be going full stroke?
Old 07-07-2020, 05:41 PM
Wow! Great ear! I owe you a beer!
One of the "driver" side (left) rocker arms is knocked out of place.
https://www.flickr.com/photos/187179.../shares/V6W4w2
Do I just stick it back in the correct spot and re-torque (ft lb?) or is there any sort of adjustment or lash I need to take into consideration?
Old 07-07-2020, 06:02 PM
If it was mine, I'd check the push rod and make sure it was still straight. If so, I'd stick it back in and run it with the valve cover off and watch the action.
You may also have a stuck valve which would let the pushrod jump out of place.
You have hydraulic lifters and the adjustment procedure is in the manual.
If the push rod is bent, you may have more serious problems.
Old 07-07-2020, 07:05 PM
Thanks ,pushrod looked straight to me. My guess is that the rocker pivot bolt just backed out. Everything seems pretty good right now. Thanks a lot for your help!
Old 07-07-2020, 11:56 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
you could have a valve seat floating around
I had one do the same thing
put it back on and ran ok for a week or so
then same problem
pulled head and found valve seat was out of head
there is no lash adjustment on the command engine, they have hydraulic lifters. just run the bolt down all the way and snug it up good. I'm sure there is a torqe spec but I don't know it.
spec is Rocker Arm Screw 18.1 N·m (160 in. lb.)
JD x475
Old 07-08-2020, 06:40 AM
dale c. dale c. is offline
sometimes the threads will pull out of the head and let the bolt come loose. if the threads are stripped you'll need a helicoil to fix the threads
Old 07-08-2020, 10:45 AM
bugeye bugeye is offline
That picture looked just like one of my engines. I rolled the pushrod on glass. It seemed straight. Put it together and has run for a few years without incident. Hopefully you have similar good fortune
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
