XLT1050 VT with Hydro Gear 618-0319. 2009 model with 300 hours on it. Hydro makes noise...load at first but then gets quieter. I decided that this is normal noise. Tractor drives slow and any effort, such as not going down hill, causes it to slow to a stop almost. Hydro is full to within 3/4 inch from top. I was told that these sealed, maintenance-free hydros usually are very dependable and that air in the system is unlikely the problem. The belt being loose is more likely the problem.
I climbed under and examined the belt area. The brake pedal must be pushed down at least half way before tension on the belt is released. If I pull on the belt it take very slight effort to make the tensioner pulley move. I wonder if this is a sign that the tensioner spring is weak or stretched? How do I check for proper tension on the belt especially since the tensioner moves so easily as to cause slack in the belt? What is the proper procedure to check tension? How should I examine springs? Any advice is appreciated. |
I'm not familiar with that model.
I have seen many LT1050's exhibit those symptoms and it's usually worn bushings in the foot control linkage.
JD x475 |
have someone else watch the fan and pulley on top of trans. when the tractor stops moving to see if the pulley is still spinning
2 questions...
Guyina4x4: How can bushings cause lack of power to wheels? Possibly slop in linkage is causing control arm on trans to not move far enough? DaleC: Yesterday I jacked up the read endand started the tractor. Without moving the pedal the belt was moving. But I did mot check the fan. I'll go out now and come back with some more details hopefully. Thanks. |
With F/R pedal in neutral position the fan spins. When pushing the brake pedal down the fan stops.
put a load on it [driving tractor] and see then if the belt is slipping the fan will slow down
Gonna be hard to do that but I'll figure it out.
When was the last time the belt was replaced?
And are you sure the belt is still routed between the idler pulleys correctley? |
When you press the brake pedal, it removes tension from the belt. If possible, remove tension from the belt and spin the hydro input pulley by hand. It should spin nice and smooth. If notchy while spinning, then there's a strong possibility that the hydro is on it's way out.
The resistance that the hydo provides to the drive belt system is enough to make even good belts slip. Belts stretch with age and when they stretch they slip even more. Replace the belt and eliminate the obvious. |
