Old 05-05-2020, 09:09 PM
Johnnysalami1957 Johnnysalami1957 is offline
Default Hydro pedal damper
I have a 3240 with sticky motion pedals. Does anyone think I could improve it by disconnecting the damper piston? I cleaned and lubed the linkages and the bearings on the hydro drive plate. The shaft going into the hydro moves freely and the tractor has a good neutral. Speeds in forward and reverse are good. I removed the piston and it seems fine. dampened in one direction and free in the opposite direction. Maybe a lighter return spring? Thanks for any insight.
Old 05-05-2020, 09:20 PM
Welcome to OCC.
I had a similar issue on my 3165 this year. I found that the large brass looking hex flange bearing going through the frame was the problem. #40 on the parts look up. https://www.cubcadet.com/en_US/ari-p...373442e1ade4/y
Disconnect the linkage going to the hydro and see if the pedals move easily. The left side one on mine was binding so I lubed it up good and worked it back and forth. This solved my problem and maybe it will yours too. Let us know what you find.
Old 05-06-2020, 09:29 PM
I'll check it out tomorrow.
Thank you!
Old 05-08-2020, 12:56 AM
Welcome to OCC.
Just wanted to thank you let you know that one of the bushings you told me about was the problem. A little heat and I removed it, cleaned the shaft and bushing and assembled with a dab of grease. Now it's perfect! Pedals are as smooth as silk.
Thanks again for the help. It's appreciated.
John
Old 05-08-2020, 05:22 AM
Great news and thanks for reporting back. Got any pics of your 40th anniversary machine?
Old 05-08-2020, 08:17 AM
Default Some pictures 3240
I have to repair a missing bolt on the upper left of the valve cover. I'm doing that today. I bought this on ebay a few weeks ago for 1800.00 and the seller said it was perfect. Under 500 hrs.Well after 250 in parts and a couple days labor I'm selling it at a loss for 1800.00. Everything is good except the fuel warning light stays on so I removed the bulb and I disconnected the seat switch. New grommets on the fuel sender and pickup tube. Brand new blades and all tires. I bought it because my wife can't work the ZT I have. I went out and got her a JD X730. She's happy now.
