Old 04-14-2020, 12:55 PM
Stoltz80's Avatar
Stoltz80 Stoltz80 is offline
Default Spindles
One of my spindles is trashed. The threads to hold the pulley on are stripped out. My question is what was the spindle part number before the use of the 745. The deck is a 422U1113. I was told the bearings were pre 745 with this deck.
Old 04-14-2020, 05:34 PM
IF, you want to go backwards to the previous style of spindle bearing assembly, by the time you buy the spindle, bearings, spacers, seals, and housing you will spend $300-$400 by the time you get an old assembly ready. You can spend $80.00 for a ST-745 Bearings and be way ahead.
Old 04-14-2020, 06:48 PM
ironman's Avatar
ironman ironman is offline
Or $40.00 used...
https://www.ebay.com/itm/IH-Cub-Cade...e/153888779594
Old 04-14-2020, 06:56 PM
I missed the part about wanting used. But that will work if he wants to go in that direction.
Old 04-14-2020, 07:06 PM
ironman's Avatar
It never hurts to have a spare on the shelf either.
Old 04-16-2020, 12:23 PM
Stoltz80's Avatar
I was told doesn't have the 745....the bearings are way cheaper...like 20$ for the tapper tho ..how will I spend more? I need the actual shaft for the old style for one spindle because threads are chewed up and the pully is gone ...does anyone have the pn for this style
Old 04-17-2020, 07:32 AM
Sorry, I either mis-read or misunderstood your situation.
Old 04-17-2020, 09:21 AM
ironman's Avatar
Does this help?
Old 04-17-2020, 12:51 PM
Vrobert's Avatar
Vrobert Vrobert is offline
Default Why new, when you can waste a day and rebuild them?
Just to stir things up a bit, I did rebuild a set of these.
https://www.amazon.com/A-I-ARP-BEARI.../dp/B072MYRKVF
It is only practical if the races aren't pitted. Just a matter of replacing the balls and seals. And it's time-consuming. Who has that kind of time these days?
Here is the story, if you have nothing better to do:
https://www.onlycubcadets.net/forum/...ad.php?t=53209
Edit: Full disclosure, today I disassembled a set of these that were nearly seized and the races were too pitted to salvage. If they still spin but are noisy I might bother to replace the ball bearings. I did rebuild one set that now roll pretty smoothly.
Also the plastic ball cages can be pulled out with a bent wire but if the cages are metal you'll have to pry them out with a screw driver and bend them back into shape if you decide to reinstall them.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 05-19-2020, 10:44 AM
Stoltz80's Avatar
Well it turns out it had the 745 Bearings. I did the one and realized the other putter is pretty sloppy. It's getting done soon. The center one isn't bad at all though. I figure it has less horizontal load and will outlast the outers.
