Old 04-07-2020, 07:31 PM
mrfred54 mrfred54 is offline
Default 1250 hydro
What is the weep hole for on top of the relief valves. I have one that leaks. Can it be brazed shut?????
Old 04-07-2020, 07:38 PM
The weep hole at the top is a "vent" hole. If you have fluid coming out, then (A) replace the relief valve , or (B) have it re-built.
Old 04-08-2020, 08:29 AM
Thanks...guess I will get a new one
Old 04-08-2020, 09:39 AM
Here are your 2 best options.
Rebuild. Many on here have sent them off with no issues.
http://www.machtechdirect.com/
New ones that are cheaper than Cub Cadet.
LJ Fluid Power Inc
10118 S M 43 Hwy
Delton, Michigan 49046-9602
Tel: 269-623-4150
Part No: 9500085 Auto Check Valve (auto release valve)
Old 04-09-2020, 07:04 AM
Thanks will give them a call. Cub cadet new is $185
Old 04-09-2020, 08:27 AM
Vrobert's Avatar
Vrobert Vrobert is offline
If one were to switch the release valves, putting the leaky one in the reverse position, perhaps it would be livable as-is. Maybe hose it down once per year until you find a donor tractor for $50 bucks somewhere, with a good valve. It can happen!
Yes, I'm cheap
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 04-09-2020, 09:51 AM
cooperino's Avatar
Yes, I'm cheap
You could do that, and then you run the risk of forgetting to keep eye on fluid, run it dry, damage more, and have to spend more money and time to repair it plus still have to replace the valve.
Old 04-10-2020, 07:15 AM
Ordered one from lj fluids $60 less
