Old 03-27-2020, 01:46 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default So, the Diesel stopped delivering fuel.....
Step 1.
Remove all sorts of stuff.
Step 2.
Remove bung from bottom of tank.
Eureka. Black Jell-O!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-27-2020, 01:59 PM
green407's Avatar
green407 green407 is offline
Yum, looks tasty.
128 X 2, 129, 149, 1250, 1450 x 2
Old 03-27-2020, 02:28 PM
Your bung hole looks nasty!
Old 03-27-2020, 04:39 PM
yall sick puppies Ha,LOL!
Old 03-27-2020, 04:46 PM
cooperino's Avatar
And in a time where TP is so hard to find...
Old 03-27-2020, 06:04 PM
jbrewer's Avatar
I used the pneumatic bidet (compressed air).
Ordered some new BUNGS from CC parts.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 03-27-2020, 06:06 PM
How does the filter look?
Gonna replace all the lines as well??
Old 03-27-2020, 06:15 PM
jbrewer's Avatar
Both filters look good (the one before the lift pump and the canister) but I ordered a new tank petcock/screen assembly as THIS one had no screen (though I suspect it should have, for just this reason), and some new BUNGS. I replaced the canister filter last year. Thankfully none of this gook got through but jammed up the tank valve.
Lines were clean... blew air through , and nothing but clean diesel came out. I'll order all new lines and redo them as they are getting kind of inflexible.
Anyone use diesel treatment to avoid these things, or is is snake oil?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 03-27-2020, 09:50 PM
BCDSFCRET BCDSFCRET is offline
Default Bcdsfcret
What you have is algae in the diesel fuel. Algae loves to hide in the pores of a poly fuel tank. What I did to kill the algae in my fuel tank on my 782D was to clean fuel tank than I added about a gallon of gas. I then shook the fuel for a few minutes. Drain the gas and blow out the tank till it was dry. Replace all the rubber fuel lines.
My 782D has been algae free now for two years.
Good luck!
Brian
Old 03-28-2020, 05:44 AM
twoton twoton is offline
I've had good results killing algae in diesel fuel systems with Power Service 'Bio Kleen'.
