Old 03-22-2020, 08:36 PM
akear akear is offline
Default Spring Assist Question
Hi... My 125 was missing the rear panel that goes between the fenders, so I picked one up and went to put it on but found this spring assist bracket is in the way. After some research here I see that this spring that attaches to the implement handle appears to be an original accessory to aid lifting heavy implements. Is it installed correctly? If so does that mean I should not have the rear panel fitted if I have the spring assist? Thanks.
Old 03-22-2020, 09:13 PM
athomas's Avatar
athomas athomas is offline
Here is a link to the instructions in the tech section of implements here on this site, says the rear panel is to be removed ! hope this helps .
https://s3.us-east-2.amazonaws.com/c...Install+NF.pdf
Old 03-22-2020, 09:56 PM
Thanks for the quick answer. Shame I sourced and repainted a rear panel for nothing but oh well.
Old 03-22-2020, 10:39 PM
IHCubCadet147's Avatar
The 125 I just got has a spring assist and the rear panel.
File Type: jpg D1A73410-9BE0-49F6-ABC7-31D8F3A5D9EC.jpg (22.4 KB, 129 views)
Old 03-22-2020, 10:58 PM
Yes it does! I couldn't get the bottom panel bolts in with the spring bracket in the way but will try again tomorrow. Or maybe just use the top panel bolts, which in retrospect should be fine. That panel is just decorative after all.
Old 03-23-2020, 10:01 AM
Red Dave Red Dave is offline
My 123 with the spring assist on the lift looks exactly like that 125 in the picture, as did my 125 before I put a hydraulic lift on it.
Old 03-23-2020, 05:57 PM
That looks better. Attaches with just top panel bolts with spring assist.
Old 03-23-2020, 08:35 PM
Yeah. Dad's 125 has a spring assist and a top panel, has had it for years. Glad you got it figured out.
