Old 03-01-2020, 09:19 PM
Rcook09's Avatar
Rcook09 Rcook09 is offline
Default Cub cadet 784 ignition problem
First off hello everyone and thanks for adding me to the forum. I just recently got 2 new to me cubs one is the 782/784 and a parts tractor 680 I’m having problems with the 784 ignition system, I have power to the coil when the ignition switch is in the on and on with lights position but when I put the switch in the start position it looses power to the coil but does turn over. It will sometimes start when I let off of the start position only bc the engine is still turning enough to get a last minute spark for the point then to the coil. What could be causing this? It’s frustrating reverse relay?
Old 03-01-2020, 09:37 PM
Rcook09's Avatar
Here’s a picture of them the 680 is rough well they both look rough I guess lol
File Type: jpg 7EE52EB0-9A13-4263-8543-C08DA70DAEFC.jpg (21.9 KB, 142 views)
Old 03-02-2020, 07:00 AM
First, welcome to OCC.....
The starting issue sounds like a bad 725-3021 Ignition Switch.
Old 03-02-2020, 07:45 AM
Welcome and thanks for the pick's
We have seen rougher.
Check/replace the the ign switch as Roland suggests.
The plug on the back of the switch is known for problems as is the switch itself, especially when they are exposed to the weather as your pix's would indicate.
What you will find is the male spades on the switch corrode, reducing the conductivity, producing heat and most times melting the plug, mostly the one from the battery.
sometimes wiggling the plug produces a temporary "fix" only to occur again at usually an inopportune time.
Also one finds the spades on the switch are loose on the attaching rivets.
Other times they are plum rotted off, or so corroded they break off easily.
Bottom line, replace the switch with the correct one AND the female terminal ends/plug.--- delphi-packard GM 56 series
Example: ebay listing # 382231331196
There are also some that sell the plug on a pigtail with terminals attached to wires.
Have fun!
Old 03-02-2020, 08:56 AM
ironman's Avatar
ironman ironman is offline
I agree that the switch is the obvious problem, but nothing was mentioned about the 680 having start problems and both tractors take the same switch, so isn't the logical thing to do is swap the switch from the 680 into the 782 and verify a bad switch.
Also, I don't believe the 782 is equipped with a "frustrating reverse relay".
Old 03-02-2020, 09:20 AM
That would depend on the Generation of the Wiring Diagram used.
Old 03-02-2020, 09:55 AM
While a viable idea, sometimes in that old of machines, disturbing the wiring harness and or plugs, one winds up having to replace components in both machines because of degradation/frailty of components.
There are 2 wiring configurations, depending if it is a Ih built or CCC/mtd built.
The latter has the reverse relay.
Add to that if a magnum happens to be swapped in, there is a modification to the wiring with a relay added or a different ign switch.
(Prolly not the case in this situation as OP mentions it has an ign. coil)
I'm betting the ign switch internally, has lost its contact caused by the internal sliding contacts erosion.
Only un crimping the terminal board from the switch body would reveal that.
Blaw Blaw Blaw I'm too long winded
Old 03-06-2020, 11:14 AM
Rcook09's Avatar
I am thinking it is the wrong ignition switch I’m going to pick one up today that is the right one
Old 03-07-2020, 07:52 PM
Rcook09's Avatar
The 680 is a parts tractor and the ignition switch was never in it when I got it, I put a new “correct” ignition switch in the 782 and still am having the same problem but I did make head way it now shows it’s charging on the amp meter. Could someone point me to a wiring diagram for the ignition switch? And yes it does have the reverse relay.
Old 03-08-2020, 07:55 AM
ironman's Avatar
This might be it.....
https://www.cubcadetpartsnmore.com/u...737_624%29.pdf
