Old 08-04-2010, 10:08 PM
jeffscub's Avatar
jeffscub jeffscub is offline
Default carb rebuild kit
guys, i need the part number for the correct rebuild kit for my kohler 26 carb. i have searched and came up with several different numbers. one replaces this one and this and that. mine is a kohler 26 and i also need the float and it's part number. i've had the same luck with this also. thanks jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 08-04-2010, 11:33 PM
Lonestarcub Lonestarcub is offline
Default Carb & Float Numbers
Jeff,here are the Kohler numbers for your #26 carb.
Carb kit #25 757 01-S
Float kit #25 757 03-S
Hope this helps,Bruce
Old 08-06-2010, 05:24 PM
jeffscub's Avatar
bruce, YOU are THE man!!!!! thank you!!!!!! jeff
Jeff
