Go Back   Only Cub Cadets > Resources > What is it worth ?
Old 09-09-2019, 06:32 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default 2182
There's a 2182 near here that "wont move because it needs new relief valves".
Does that sound plausible, and are there other checks I can do to increase the confidence that that is what is actually toast with this neat old (running) tractor?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 09-09-2019, 07:03 PM
The 2182 has a Sundstrand Hydro Unit in the tractor. When the engine is off, and there is no hydraulic pressure, the Relief Valves should open and allow you to push/pull the tractor.
Old 09-09-2019, 08:05 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I think it would be unlikely that both forward and reverse relief valves to be malfunctioning, unless seller has been using tractor as parts machine (you get the bad parts). I think something along driveshaft could be the problem.
Go and look. Take little money. Offer low. The seller needs to be motivated to sell low because it don't move. I'm was thinking maybe take extra relief valves if you have any....I'm not sure about that, because if tractor works again then seller will want more money.
Plow blade
#2 Cart
QA36 snowthower
Old 09-09-2019, 08:55 PM
The worst that could be is a frozen brake.
Is it a 150.00?
Old 09-09-2019, 08:57 PM
I think he means, the po, that it will not move when running.
Old 09-09-2019, 09:34 PM
cooperino's Avatar
Only way to actually "check" would be to plumb in a gauge. I would bet money it's a stuck valve as the seller said tho
Old 09-09-2019, 10:47 PM
SS5150's Avatar
SS5150 SS5150 is offline
I wouldn't give a lot for it but I sure would go look. 2182 is a lot of tractor.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 09-10-2019, 01:10 AM
Are we talking a $200 dollar won’t move or a $1200 won’t move price John? A good running WG should bring $500-600 + all the other goodies.
Old 09-10-2019, 10:06 AM
This thread has turned into a "What is it worth" so I moved it.
Old 09-21-2019, 09:17 PM
CubDieselFan's Avatar
Did you get it?
