Old 09-07-2019, 12:52 AM
CubRookie CubRookie is offline
Default 42 inch Deck Height problems
So I just Rebuilt the deck on my new 104 everything is good. I check the level of the deck at the blades both sides measure on the money at 1-1/2 left to right. Front to Back has a 1/16 drop in the front. Here's the problem! Pull the lever one click up. Right side measures 2-1/16 Left side is 2-1/2. I cant find the problem. None of the metal seems bent or in a bind smooth up and down movement. Anyone have any ideas?? Also I cant get much movement left to right from the front ajustments. I guess I'm just not understanding the front adjustments. Any help is appreciated.
Old 09-07-2019, 06:27 AM
As a suggestion, look at the "lift arms" to make sure they are on the same plane.
Old 09-07-2019, 12:24 PM
More than likely it is the deck lift link that attaches to the lift lever. You can get an adjustable for the low side.
Up to 534 and counting...
