I just finished a rebuild on a Cub Cadet 100 early 60s . I rebuilt motor, clutch, electronics, etc. I bought a creeper gear for NF from a cub Cadet parts supplier.
I broke the tractor and installed the creeper with gear on transmission and pin. I have just completed the job and everything works great except the creeper appears to be always in hi gear . I initially used 75-90 w gear oil in it and just changed to 30w. To my dismay it will not move to the lower gear with 4:1 ratio. It only goes halfway in the gear slot towards the rear and does not hit the front metal of the slot. Any ideas. I used the pin to install the gear on transmission side and bolted it on with bolts and gasket supplied by store. The front side I bolted it onto short drive shaft with a 1/4 in bolt. Need help hear. Cannot imagine why it will not go into low gear. The place seemed very reputable. I put new clutch on and shortened drive shaft. Also used Kirk point saver and Bosch coil. It runs like a top and started up right away after rebuild. Please anyone have some insight what is wrong here. Before I installed creeper gear it appeared to shift fine. Thanks. Doug |
You should download the manual and see if there is an issue and get back to us.
You will have to remove the creeper to fix it.
Thank you. Will do.
Tags |
creeper gear, cub 100 |
