Old 08-01-2019, 03:10 PM
quadracerx quadracerx is offline
Default 149 Vs. 169
I have an opportunity to buy a 169... But have a couple questions:
1) I already own a 149, will the rear rototiller from the 149 fit the 169?
2) How hard is it to find parts for the 169?
The 169 already has a bucket loader. I was going to build one for my 149. So, my plan is to fix up the 169 and keep the rototiller from the 149 if it fits the 169... Then sell the 149.
Thanks for your help in advance...
Steve
Old 08-01-2019, 04:27 PM
Yes
It would the same as the 149.
Old 08-01-2019, 05:28 PM
Another thought... The 149 I have is in better shape than the 169 that I am about to purchase.... How hard would it be to take the loader off the 169 and move it to the 149?
Old 08-01-2019, 06:18 PM
Are the 149 and the 169 the same size physically? Seemed like the 169 was a little bigger, but since I didn't have them side by side I couldn't tell for sure?
Old 08-01-2019, 06:52 PM
Billy-O's Avatar
Billy-O Billy-O is offline
149 and 169 are the same series tractor. The big difference is 149 came with 14HP K321 Kohler motor and the 169 came with 16HP K341 Kohler motor. The 149 was produced from 1971 to 1974 and the 169 was produced only in 1974.
Plow blade
#2 Cart
QA36 snowthower
Old 08-01-2019, 09:25 PM
MARK (LI)'s Avatar
MARK (LI) MARK (LI) is offline
Please show pictures of each.....I am new here , but I have a 129 with a loader...it is my first Cub and I can't believe how well they are made...do you know what diameter the front wheel spindles are on yout 149 and 169 tractors?...I am looking to change out the axle on mine and go with larger spindles to handle the weight from the loader.....thank you......Mark
Old 08-01-2019, 09:40 PM
sawdustdad's Avatar
129, 149, 169 all had 3/4 inch front wheel spindles. Parts are largely interchangeable. IH went to 1 inch spindles part way through the Quiet Line series production. (800, 1000, 1200, 1250, 1450, 1650). I'm pretty sure 1 inch spindles from the QL can be put on the earlier WF (129, 149, 169) tractors' axles.
As for pictures, the 129, 149 and 169 look identical except the 169 has a larger air filter housing. The hood decals have different color stripes. Here's a 149.
Old 08-01-2019, 09:51 PM
ironman's Avatar
ironman ironman is offline
Not knowing or seeing any condition of the models being mentioned, one can only throw out their opinion of the situation as presented, so here is mine....
To own a 149 simultaneously with a 169 is almost dreamland for most people on this forum.
That being said, a person with a tiller on his 149, and then a loader on a potential 169 purchase makes the question even more insane.
With work and effort, you could have a combo of two of the most desirable garden tractors IH ever made, combinded with the two most desirable attachments ever made.
I guess I'm sayin', "if you ain't buyin', stand back and get the hell out of the way".
Old 08-01-2019, 10:06 PM
Nato527 Nato527 is offline
I couldn’t agree more with ironman! As I’m reading this post, scrolling down thinking......you’ve got to keep both.... the whole post is a trick question.
As for the axle swap, I did it on my 125. Before
File Type: jpg D601ECAA-71C9-43AD-A411-5EFC14902D1E.jpg (25.0 KB, 178 views)
Nate
Old 08-01-2019, 10:13 PM
After.
I’m not sure about the spindles being interchangeable, but I wouldn’t think it was any easier than swapping the whole axle.
File Type: jpg D3065CDA-B405-4A4D-A5CF-5F60372D8E53.jpg (37.6 KB, 176 views)
Nate
