Old 07-16-2019, 07:18 PM
caddytech caddytech is offline
Default 1782 trans leak
I have a 2082 and a 1782 my 2082 broke a con rod and my 1782 is leaking trans fluid I found a leak at the rear cover and repaired it checked the relief valves and they are ok I was wondering if anyone had any other leak spots that might help
Thanks
Old 07-16-2019, 07:55 PM
Possible leak points.
1: Cork gasket
2: Axle seals
3: Axle tube bolts (6 on each side)
4:Rear cover
5:Silicone between the main case and the adapter housing
6: Expansion plug
7: Suction tube
Now for the Pump
1: Relief valves
2: Input shaft seal
3: Output shaft seal
4: Trunnion seals
5: Hydraulic fittings
6: Miscellaneous plugs
7: Charge pump O-Ring
