Old 06-25-2019, 05:28 PM
cory1982 cory1982 is offline
Default Air Cleaner Assembly
My Air Cleaner assembly on my 129 keeps coming loose from my carb, specifically the 3 screws are what keep coming loose. Do I need to just use some loc-tite on them or whats the deal. Also, is there supposed to be any sort of gasket between the carb and air cleaner assembly? I can't find one in any of the parts diagrams so i'm assuming there isn't.
Old 06-25-2019, 05:55 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
air cleaner base gasket KH-275341
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 06-25-2019, 05:58 PM
twoton twoton is offline
Hey cory1982, welcome to OCC.
I had the same problem with one of my carbs so I glued a couple of stainless steel studs in with red locktite and used nylock nuts.
Old 06-26-2019, 09:58 AM
dodge trucker dodge trucker is offline
I have had to helicoil those holes on the carb on my 129, and on a 1250 that belongs to a friend of mine too.
Old 06-26-2019, 03:57 PM
Thank you all for the info. I will definitely be picking up that gasket and trying the lock nut method.
Old 06-26-2019, 04:10 PM
RLause's Avatar
RLause RLause is offline
That gasket can easily be made from the cardboard on a tablet back.
Richard
Old 06-26-2019, 06:58 PM
Make sure you clean out those threaded holes well with brake cleaner and then blow them out to make sure the locktite sticks.
