Old 05-14-2019, 09:49 AM
nophun nophun is offline
Default GT54 deck issue
This is on the 1863, I've checked all to online resources I can find, as well as looked for damage or mismatched parts.
The rear deck wheel on the non chute side rubs against the deck, I currently have a well worn one on there which doesn't rub, but a good one will.
My thoughts are that that corner is supposed to have a different axle or a spacer, but I don't see anything like that on partstree.
Old 05-14-2019, 10:42 AM
Here is the parts breakdown for the 190-324-100 (GT54) deck.
190-324-100
Old 05-14-2019, 11:10 AM
Rear deck wheels and casters are the same. You don't have the wheel turned to the inside do you? This is how it should be setup.
Old 05-15-2019, 12:29 AM
190-324-100
That shows both0 sides as the same part. This may be case of looking but not seeing on my part, I think those wheels can be mounted backwards changing the offset...
Old 05-15-2019, 12:38 AM
That's how it's set up; the crown of a newer wheel just touches the flange around the deck, the one I have on there now is worn flat and clears. I may have a small bend or twist in a part or the wheel backwards, luckily I have spares of everything.
Old 05-15-2019, 07:45 AM
I had a better look at my deck yesterday, it will only go one way and it is a very close fit, maybe 1/4" clearance at best. They are also easy to bend the axle / shoulder bolt so that may be your problem. Post a pic of yours.
Old 05-15-2019, 10:06 AM
Grease fittings go to the outside. If they are to the inside, that'll move the wheels I/B.
I looked at one of my 54" decks. It's a little worn on the spindle and deck mounting holes so the spindle will rotate some. Wheel and bushings are worn a little. If I backed up, the left side wheel would rub the deck.
Don't see it as a problem unless your wheel is hard against the deck.
Old 05-15-2019, 10:25 AM
Here's how it looks with old wheel on. It doesn't "look" like anything is bent, but the PO had to have hit something pretty hard at one time because I had to spend some shop press time straightening the deck hanger assembly.
Old 05-15-2019, 10:48 AM
ironman's Avatar
ironman ironman is offline
This is a 54" deck that I had a few years back. Obviously the wheels are very close but I don't ever recall them rubbing.
Old 05-15-2019, 07:00 PM
If you lower the wheels they will not hit.
