Old 05-04-2019, 09:14 PM
austinewald austinewald is offline
Default 128 Dash tower metal cracked
2 of the 4 bolts that hold it to the frame holes are cracked about 2 inches or so. How could I go about fixing this? last resort would be to replace the tower.
Old 05-04-2019, 10:28 PM
dodge trucker dodge trucker is offline
the BOLTS are cracked as in snapped off? or the tower sheetmetal is torn?
if its the tower sheet metal, I'd drill a small hole at the end of the crack and then vise grip one of my copper bars to one side if it and weld away with my MIG.
similar issue with my 129... the #10-24 bolts that hold the fiberglass cover to the metal part on the left side, snapped off on mine, knocked the welded (tacked ) OEM nuts off the back side, gonna have to tack some new ones into place.
Old 05-04-2019, 11:42 PM
sorry i mean the sheet metal
Old 05-05-2019, 03:27 PM
have some of a 129 here that I aint sure yet what I am gonna do with, but otherwise if you were closer, and you'd take the tower off, I'd weld it up....
Old 05-07-2019, 03:27 PM
J-Rodz168's Avatar
J-Rodz168 J-Rodz168 is offline
Had the same issue on my 169, stress cracks from and around the lower bolt holes of the dash tower. I made support brackets out of 1/8" aluminum diamond plate and bolted them right over the sheet metal with two additional bolts into the tower.
Old 05-08-2019, 04:08 AM
Thanks!, I do noticed ours both are made in 74, wondering was this a common thing in this year, My earlier 129 and 149 didn't have no cracks in the tower.
Old 05-08-2019, 03:43 PM
J-Rodz168's Avatar
You're very welcome sir. Not sure if it's a model year issue or not, my 128 isn't cracked though, which is a September 1973.
