Old 05-04-2019, 06:20 PM
Tom Dowling Tom Dowling is offline
Default 682 electrical diagnosis help needed-again
It started fine last year when you turned the key, this year it does nothing when you turn the key. The only way it will turn over and start is by jumping the solenoid. Here is what I've done so far---The connector plug at the key switch was melted at the spade that goes to the solenoid, both the male and female were badly corroded so I replaced the switch, spade connectors and plastic plug---no luck, still won't turn over with the key---replaced the solenoid today, no luck again, still won't turn over with the key Is there a way to test or bypass the pto clutch switch and/or the safety switches so I can fix whatever the problem is without guessing? Thanks for any help and suggestions.
Old 05-04-2019, 07:10 PM
I was wrong it does not start when you jump the solenoid, only turns engine over. I founds R.Bedell's wiring diagrams on google, thank you Roland. I am going to run a jumper between the S terminal at the switch to the little terminal at the solenoid and see what that does. By the way the serial # is 729425 ccc built.
Old 05-04-2019, 07:49 PM
Let us know how that test turns out.
Old 05-05-2019, 02:18 PM
I ran a jumper wire from the "S" terminal to the little post on the solenoid and turned the key---the starter turns the motor over---I think that leaves the brake switch or the pto switch as the culprit. I didn't try to start the engine yet. With the brake pedal in the locked position wouldn't that rule out the brake switch?
Old 05-05-2019, 04:59 PM
Your problem areas are:
* PTO Switch
* Brake Neutral Switch
* Bad Wiring between the "S" terminal on Ignition Switch to the Solenoid Coil.
Old 05-05-2019, 05:21 PM
Billy-O's Avatar
Billy-O Billy-O is offline
With the jumper from key switch to little lug on solenoid, you bypassed the brake switch.... so for now, the brake is still a possible culprit and you can't rule it out. Roland listed the likely problem areas you should investigate.
Plow blade
#2 Cart
QA36 snowthower
Old 05-05-2019, 06:46 PM
Thanks, will check those things this week as time permits
Old 05-06-2019, 05:00 PM
I jumped the two red wires at the pto switch and she started right up!! Ordered a new switch. Thanks again R. Bedell, studying your wiring diagram made things easy. - Tom
