Old 05-01-2019, 08:50 PM
xbanone xbanone is offline
Default 1450 ignition coil
I have no spark on my 1450. It has a Bosch blue coil and ran great last fall. I tried another coil off of my 108 and it fired right up. The coil was new last year and has 3.9 ohms resistance from the - to the + and 9.1k ohms from the tower to the +. Are these blue coils known to suddenly fail? Is there another check I can preform? I’m just curious as to why this one quit working.
Thanks!
Old 05-01-2019, 09:08 PM
You will never know why it stopped working.
Unless you left the key on and it smoked itself.
Old 05-02-2019, 06:27 AM
Not that we have a direct line to the Technical Service Dept at Bosch, but we have not heard of failures.
Old 05-02-2019, 08:19 AM
mickb72 mickb72 is offline
If it has that resistance now i would think it would work. Maybe you wiggled a wire or key switch just right. I would bet on the key switch failing before that coil. Did i ever say i hate key switches and old ones are even worse. Yes i have. and i have one failing on a 169 right now. Mike
Old 05-02-2019, 09:09 AM
Sounds like it's time to break out the test light.
For starters,
Make sure you have juice to the coil w/the key on.
If so, make sure the test light flashes on the other coil terminal when you crank the engine over.
If not, check the points.
Old 05-02-2019, 01:35 PM
For starters,
Since he said it runs with the coil off his 108, I would think it is a coil problem
Old 05-02-2019, 03:02 PM
It is. I have already ordered another blue coil.
Old 05-02-2019, 07:20 PM
well hell, that is the problem, a yeller tractor needs a yeller coil, not a ford blue one.
