Old 04-27-2009, 10:14 PM
wig wig is offline
Default Will briggs & stratton replace kohler kt17
I have to rebuild my Kohler, so my question is-- I have a chance to buy an 18 hp Briggs & Stratton (opposing twin cylinder)engine. Dont know the model as the side shields are gone, but was told it is from the 1980's sometime.Will it fit in my 782 without any problems? By the looks of the muffler it my be my first big problem. Any ideas on the hook up of the drive shaft to the flywheel or any other possible issues I might have if it would even work? The Briggs does come with a electric clutch also.
Old 04-27-2009, 10:18 PM
tubbyfirefighter's Avatar
tubbyfirefighter tubbyfirefighter is offline
rebuild the kolher, it will be a better investment.
Old 04-27-2009, 10:32 PM
I'd pass that up and wait for a decent KT-17 Series II, M18, or CH18 instead. The first two I mentioned will be much easier to hook up. If you try to use the briggs, the muffler is gonna be screwy, the PTO clutch may be a different diameter, which will cause issues, and there could be other problems.
Old 04-27-2009, 10:45 PM
Jim H.'s Avatar
Jim H. Jim H. is offline
I done it once with the apposing twin, If I were to do it again it would be a V twin Vanguard. for resale value I'd stay with the Kt 17. there are options not that hard to change over, I did have to buy a clutch for the briggs because of the bore being different. $285.00 will get you pretty close to a rebuilt engine doing it your self and you'll know what you have.
Every time I find the key to success, someone changes the lock
Old 04-28-2009, 06:40 AM
RPalmer's Avatar
RPalmer RPalmer is offline
Rebuild the Kohler.
Old 04-28-2009, 09:26 AM
PaulR PaulR is offline
Honda V-Twin!
http://www.smallenginewarehouse.com/...adet&Model=782
