Old 03-26-2019, 03:52 PM
CubbyRI CubbyRI is offline
Default Small pin removal frustrations
well tractor is almost totally apart, but those dam small pins (spiral and roll) just wont move. I have a (cheap) pin punch set and PB Blaster penetrant. Also, have not used my ox-acetylene torch yet but that's coming!
Trying to pull the driveshaft coupler at the transmission, the clutch-brake pedal cross over shaft pin, and the front axle pin.
suggestions welcome but it looks like may be time for some real heat... if I heat the end of that driveshaft the coupler is loose so I dont think it will overheat into the transmission input shaft, and that needs a new seal anyway...
if heating doesnt work and the pins get mangled then what? they are too hard to drill out supposedly.
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 03-26-2019, 03:59 PM
Workingstiff Workingstiff is offline
The pins look flush to the surface. Support and a 3LB hammer
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 03-26-2019, 04:09 PM
how do I support it? wood? and does torch heat ever help?
Old 03-26-2019, 05:10 PM
cooperino's Avatar
Agreed.. support it and whack it! I use my air hammer with a bit I made specifically for the pins.
Old 03-26-2019, 05:22 PM
Cut a wood block for support? As to the air hammer, I HAD one but IIRC it was a cheapo HF one and I may have tossed it for being weak. may look on ebay for a used snap-on or IR one and do it right.
As to HF, I was an HF snob but the pic of my engine hanging over the cub includes, a HF chainfall, HF alum jack, HF impact gun (which I am VERY impressed with that one!), and who knows what else... I guess no more chit-talkin HF for me!
Old 03-26-2019, 06:08 PM
Do not use heat on the coupling/shaft!!
You will ruin the heat treatment.
Support it with a jack or piece of metal on concrete and whack the pin punch with a B.F.hammer, sometimes a person can hold the pin punch with a pair of vice grips if they are afraid of hitting their hand/fingers.
If the coiled pin is mushroomed, hit it from the other end or grind it flush.
You will not get it out if it has a mushroomed head.
As mentioned an air hammer works well,
but still solidly support the shaft, as it makes
the pin come out easier.
Old 03-26-2019, 06:59 PM
There’s a small chance that the coupler to trans has spun and the pin will never come out if holes are mis aligned. Like I said small chance but worth taking a couple pipe wrenches first to try to move coupler/driveshaft separately.
Get some good pin punches with locating nub on them and good advice to drive or beat pins flush first, support, etc.
I’ve beat shafts out breaking roll pins as last resort then you have 3 separate pieces to knock out BUT last resort. Use brass punch in this case.
Old 03-26-2019, 07:14 PM
Alvy,
over the years, I have seen the broken pin situation more than rarely,
one example is on a QA snow thrower drive sprocket.
Old 03-26-2019, 07:47 PM
lwrehm lwrehm is offline
A couple years ago I had a hell of a time getting the pin out of the drive shaft of one of the 102s. Ended up using one of those punches with the ball end (no clue what they are called) with a cheap Harbor Freight are chisel. Used a coupling nut that the punch would fit into and a bolt with the head cut off as kind of a holder to keep the punch and chisel in contact. Still took a hell of a time to get it out.
Once it was out I figured out why it was such a bear to remove, this may not be a very good picture but you should be able to see the ridge it was hanging on...
Old 03-26-2019, 07:55 PM
Success. OK I couldnt get the rear end out with the driveshaft attached because the clutch end wouldnt have come out. I didnt try to take that apart. I DID use heat on the driveshaft end (sorry George didnt see your post until I came back inside), it was the only way I could get the pin to budge, but quenched it in water to hopefully restore some hardness. If not, I'll have to source another less rusty shaft (or make a stainless one on my lathe?).
Got the rear pin out easier (no heat obviously on the input shaft).
As to supporting it, an impact socket wedged under the coupler worked perfect.
Got the brake pedal shaft off too, that was a lot of work, including power sanding the paint and rust off that shaft so I could slide (hammer/pb) the bellcrank off of it as it came out. The differential water came out too.
Now, the front axle pin is the issue.
The pin is stuck firmly in the axle. Blows with a splitting maul did nothing but pean over the end. It is very loose in the frame bushings, so I can make new ones and weld them on. Should I heat the cast iron axle center, the big stuck pivot pin, or do something else?
Thanks for all the help
