I need to make a temporary fuel tank for a tractor I am working on and was thinking about using 4" PVC pipe. Anyone know if it is compatible with diesel??
![]() Quote:
But there might be an issue with static electricity in some large applications without grounding. In your situation using it for a temporary small engine fuel tank, I don't see an issue. ![]() |
Static electricity you say...Hmmm...
![]() Now you got me worried there ol'George. |
We have a temp tank at work made out of PVC. We use it for gas and diesel and have been using it for 10yrs now without issue.
You use it to run tractors that you're restoring?
Got one off a Briggs, must be 30 years old--it was on a cement mixer and still has cement splatters. Has a valve under the bottom and a bracket where we can tie it on or bolt it down (if possible).
Valve's a good idea.
We use it to test run tractors so we don't have to mount the real tank.
I'm checking out a tractor for a friend. It's been sitting in his barn (that I built for him) for over 20 years. The tank, even though full of red fuel, is very rusty. The filter had some brown crud in it that felt gritty but my magnet wouldn't pick it up. Maybe algae but I never came across any gritty algae???
![]() The fuel that came out of the filter was surprisingly clean but did not smell like any diesel that I ever smelled so I drained the whole system and plan on setting up the temporary tank with new fuel line and filter before I try to crank it over. |
The Surplus Center ,has some cheap metal tanks
last time I looked |
