Old 07-23-2010, 03:14 PM
dale.l dale.l is offline
Default How many wheel weights do you use
How many wheel weights do you use on your cub that is used for plowing? I have 3 sets, I was going to put one on the inside and 2 on the outside. think thats over kill?
Old 07-23-2010, 03:45 PM
When I get the 149, I'll use one set of wheel weights.
Old 07-23-2010, 04:12 PM
gcbailey's Avatar
gcbailey gcbailey is offline
how many pounds are you talking? On my GT2544 I've got fluid filled tires and up to 75lbs in weights on each side depending on where I'm mowing.
Gary
Old 07-23-2010, 04:38 PM
Merk Merk is offline
Which kind of plowing are we talking about? Moldboard or snow-dirt removal?
Moldboard plowing:
149-100 pounds (sitting on seat) on right side/left side-140 pounds including dual.
100-65 pounds on both sides
86-150 pounds on left side and 100 to 120 on right side
Plowing snow:
149-100 pounds on each side.
Have a blade for 100.....needs paint before I use it.
Old 07-23-2010, 09:28 PM
Leon renaud Leon renaud is offline
I have the same weights my father in law ran on his 2 Cubs he ran 1 inside each rear wheel and 2 outside this set up has worked since 1965 on his first cub then got moved to his 682 in 80 and they are still on it.
Old 07-23-2010, 09:50 PM
johncub7172's Avatar
I run 2 50lb. weights, one on each side. Then I have a cool 7- 10lb. steel lifting weights on the back of my custom hitch along with a 12ft. 3/8 logchain over the back. Then I'am about 185lb. Dont think I can get away with only my 4-link tirechains because the IH 42" pushblade is respectably a heavy outfit and I may just spin. I dont care to overload my machine too much because it only wears it out quicker in my opinion. Just hard on everything in general, but if you never had a problem....run-whatch-ya brung!
