Old 03-13-2019, 06:55 PM
Squirtspop Squirtspop is offline
Default Model?
How would one figure out the model of an IHcub without the decals? I have two believed to be of years 1968 and 1972
Old 03-13-2019, 06:59 PM
IHCubCadet147's Avatar
Do you have a picture of them?
Old 03-13-2019, 07:44 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
A 1968 year would be a model 72 or a 1x4 or 1x5 model.the 4s are gear driven, the 5s are hydrostatic.
The 1972 year would be a model 86 or 1x8 or a 1x9 model. The 8s are gear driven and the 9s are hydrostatic. Pictures would be helpful.
Old 03-13-2019, 07:47 PM
ironman's Avatar
ironman ironman is offline
So would serial numbers.
Old 03-13-2019, 10:06 PM
Where are the serial numbers located? I am working on the older one and haven't seen a tag on the frame as of yet. Bother are gear driven with a "hi - lo" pre-drive
Old 03-13-2019, 11:08 PM
It should be on the bottom left corner of the transmission.
Old 03-14-2019, 08:09 AM
ironman's Avatar
S/N locations....
http://cubfaq.com/serialnumbers.html
Old 03-14-2019, 07:46 PM
Found a number in the casting for the transmission "385058R1"
Can't figure out how to add a picture
Old 03-14-2019, 08:42 PM
cubs-n-bxrs's Avatar
That looks like a casting#. The serial # should be on a tag on the back of the rear end. Should be mounted to the left of the rear cover.
Old 03-14-2019, 08:50 PM
finsruskw finsruskw is online now
Could be stamped into the reduction housing on a square boss or into the rough casting itself like the originals.
Really small numbers, may be painted over and hard to read.
If on a tag left rear side of the differential housing, and the tag is missing, there should be evidence of the holes or maybe the rivets will still be there
