Should be simple, I know. Everything says pull the 4 pins, and slide it out the side. The front two I could work loose from the eye bolts. The rear two, though..how do you get the horizontal lift frame off the pins? There is a cross brace welded that keeps the bars from spreading. The pins are welded in the brackets and the brackets are bolted to the deck. I ended up unbolting one of them to get the job done. There must be some trick I’m missing. Thanks?
Do those rear pins not have springs on them? just pull them out and it should settle down. Put your lift bar forward.
I believe it’s sounds like he has a pin on deck and not a QA deck.
Yep, these are short solid pins drilled for hairpins or cotter pins.
My bad. Sorry.
I wish it had those. I’ve had a Bolens and Gravely both that did. This one, however, isn’t so lucky..
It sounds to me like you have a "pin on" mower deck and a "quick attach" sub frame. You can see the "QA" frame has a welded cross bar back near the rear holes, the "pin on" does not. With the "pin on", once you remove the hair pins you can spread the frame easily enough to get it off the pins.
I believe you’ve hit it exactly.Not the only odd thing I’ve found on an otherwise pretty nice Cub. PO had it wired positive ground, for instance. So, would QA brackets bolt to the deck? Seems that would be the best option. Second would be remove the cross brace. I’d rather have the QA pins though.
OK, Thanks!
