Old 01-23-2019, 01:58 PM
Frank1541 Frank1541 is offline
Default Strange charging for Command Engine
The charging light on my 1541 (with newer command in it) does not turn on right away. After a few seconds or up to a minute after starting the light goes on. I checked the voltage output and it starts at 13.8v. It then drops to under 12v after a while. Probably the regulator. Has anyone else seen this?
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 01-23-2019, 02:14 PM
Common problem with the Cyclops tractors. Easy fix, take the bulb out and throw it away. If you want to know what is going on put a voltmeter in the dash. Check the ground on the VR.
Old 01-23-2019, 03:22 PM
I will check the ground again. These things always happen when I am trying to move snow off the drive way.
Putting a real meter on has always been on my to do list. Time to make the move.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 01-27-2019, 09:33 AM
Problem solved. Replaced the 7 year old battery and cleaning the contacts. Not sure which solved it.
Now I am ready for the foot of snow forecast for tonight.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
