Old 07-20-2010, 10:08 PM
bigdaddyjak bigdaddyjak is offline
Default 123 head
took the head off of my 123 and there is a piece missing by 1 of the nolt holes, something caused it to blow a chunk out. now I no why it started running rough ,lost power and would not start back up ! what would cause this? I was mowing along and it ws running just fine, then bam ! I have another head, get a gasket and throw it on??? was this just a bad cast, or something else cause it, everything else looks good and turns freely. I ve been trying to put a pic on, I have tried 4 times now and it wont work
To much to list!
Old 07-20-2010, 10:24 PM
I'd say that's what happens when you have a blown head gasket and it isn't fixed. Don't toss the head...it can be TIG'd and flattened and it will be fine. Make sure the new head is flat before installing the new gasket.
If you aren't in the hurry, I plan on doing a head gasket replacement how-to tomorrow...
Old 07-20-2010, 11:22 PM
finally got a pic up !! I will check the head and be sure it is flat , before i install it and the new gasket. Thanks MATT.
To much to list!
