I was parting off some material in my lathe when it started slipping in the chuck. I reached down to the headstock and grabbed the spindle lever and swiftly lifted it up to stop the chuck. I heard "clunk"
![]() (pic 1)Turned out the knob on the end of the lever broke where the previous owner welded the knob on with nickel rod. ![]() One of my friends is very experienced in brazing and offered to fix it for me. I took it off the lathe on Thursday night, bead blasted the knob and the end of the lever on Friday. Saturday morning went out to Rough and Tumble where my friend Bill brazed it. He ground the snot glob weld down to get closer to original shape and ground a chamfer on both pieces. pic2- preheat and adding flux pic3- brazing the first side pic4- brazing the opposite side pic5- after grinding a few minutes on the scotchbrite wheel to remove sharp edges pic6- installed on the Monarch CK 12 and back in business |
Lol.. dont know your own strength tough guy
There is bound to be a good story as to how that broke in the first place.
I did move the other lever quite quickly.
![]() Quote:
We could all guess till hell froze over what happened, and we all have stories.
Glad you have it fixed The lever is prolly cast iron and a good nicast rod done right would of still held. Nothing wrong with brazing in that application tho' ![]() I'm sure if that ol' Lathe could talk, it would have some stories to tell. Glad it is in good hands. I've had mine near 50 years, wished the original owner was still around to know it is still making chips, when needed. |
![]() Quote:
Yes, the lever is cast iron and I'm not a fan of nicast rod. In the rod holder of an experience welder with proper cooldown it has a chance to work but can fail at any time NEXT to the weld as mine did. Brazing works at a lower heat and doesn't draw the carbon in the cast iron to the surface like welding does. |
You know a well used machine by the polished knobs on the levers!
![]() You know you can't go wrong with those old machines if they're well taken care of. And the machine is lucky to have you.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
![]() Quote:
Mine is post war age,----------- FIRST world war that is. My South Bend lathe just turned 100, built on Nov 14 1918. I bought it from the original owners nephew in '69 along with a 30" Rockford shaper The Shaper gets little use since I got the B'port some years ago, and is worth more in scrap than in resale today. Too heavy/slow and nobody wants/needs them,or knows how to use them for that matter. Guess I'm getting older than I thought, but it doesn't seem that long ago, that I learned in high school how to use them all. Back in them days they had shop classes, unlike today. But there is hope, as they are in need of skilled trades and are scrambling to find help I'm told. Sorry for the rambling. |
Came out real nice Jeff.
Your knobs are very shiny from making the PBJ stuff.
